Cannot access published service
3265
10-24-2012 08:21 AM
BrianGreen
New Contributor II
Hello,
We have two ArcGIS 10.1 servers running on RedHat Enterprise Linux 6.3 that are clustered - when I access a service (from the arcgis/rest/... web page) on one server it works fine, but on the other one I get a message
Error: Error handling service request: Could not find a service with JNDI name 'service' in the configured clusters. Service may be stopped or ArcGIS Server may not be running.
Code: 500
I've restarted ArcGIS on that server - no luck.  This is the server that the service was published on.  In the ArcGIS Manager it shows as Started.
This is happening to a lot of services!
Any ideas?
BrianGreen
New Contributor II
It seems this was related to the cluster definition - I deleted then re-created the cluster, and the problem resolved itself.
TomMagdaleno
Occasional Contributor III
I had a problem with my Service log on that gave a similar result.  When I changed from local system account to This Account it fixed the problem.  It could also be a permission issue in the file tree somewhere.
BrianGreen
New Contributor II
