Certificate for secure map service connection untrusted
1633
01-22-2013 07:45 AM
StephanieSnider
Occasional Contributor III
ArcGIS Server 10.1 SP 1
Windows 64-bit OS:  Windows Server 2008 R2 Standard, Service Pack 1
I set up SSL and https on my arcgis server (NDEP-25), and it seemed to be working.  I can go to this internal website (https://ndep-25/arcgis/rest/services), but get the browser error �??There is a problem with this website�??s security certificate.�?�  When I click �??Continue to this website (not recommended)�?�, I can connect fine.  I thought this was acceptable until I tried to make a secure connection in ArcCatalog to the map services on NDEP-25.  I'm getting errors that the certificate is untrusted.  See attached screenshots of errors.
I tried to install the certificate by �??Automatically selecting the certificate store based on the type of certificate�?�.  It says the import was successful, but I still get errors about the certificate not being trusted.  I�??m currently using a self-signed certificate generated from ArcGIS Server.  The Web Adaptor works.  I successfully completed the instructions at http://resources.arcgis.com/en/help/main/10.1/index.html#/Enabling_SSL_using_the_default_self_signed...
If I click Yes to proceed on both warning windows, I can connect to the map services.  However, this is not a good practice.  We need these map services to be truly secure.
Any suggestions Network Gurus!?!
[ATTACH=CONFIG]20957[/ATTACH]
