When attempting to run the configurebackuplocation.bat command, we get the following error:
d:\<datastoreinstallpath>\tools\configurebackuplocation.bat --location \\<uncpathtoshare>\relational --store relational --operation change
You are attempting to change the backup location of the data store. For a relational data store, existing backups will be copied to the new location and it could take a few moments. For a spatiotemporal big data store, the data store service could be restarted. Please do not interrupt the process once it has started.
Do you wish to continue (Yes or No)?Yes
Error encountered: Failed to generate a token for the user.
When we configured the relational datastore, we provided credentials for the ArcGIS Server hosting server (initial admin user). Isn't this command using the same credentials as the configuredatastore tool? describedatastore also shows no Portal URL because we set up the DataStore with the AGS hosting server before we federated it
Windows Server 2012
ArcGIS Server, DataStore 10.7.1
What credentials does this command use or can you pass it different credentials?
