Hello, while I was trying to install base ArcGIS Enterprise deployment on one machine using the script in simpleConfigs and I imported the ArcGIS Module
first i got that error belwo:
Invoke-ArcGISConfiguration : The 'Invoke-ArcGISConfiguration' command was found in the module 'ArcGIS', but the module could not be
loaded. For more information, run 'Import-Module ArcGIS'.
and i run this "Import-Module ArcGIS"
then i tried to rerun the script
Invoke-ArcGISConfiguration -ConfigurationParametersFile 'C:\Users\ahmed.fathy\Desktop\BaseDeployment-SingleMachine.json' -mode Install
i got another error
[ERROR] DSC Module only supports ArcGIS Enterprise 10.7.x and later versions.
At C:\Program Files\WindowsPowerShell\Modules\ArcGIS\ArcGIS.psm1:699 char:17
+ ... throw "[ERROR] DSC Module only supports ArcGIS Enterprise ...
+ CategoryInfo : OperationStopped: ([ERROR] DSC Mod...later versions.:String) [], RuntimeException
+ FullyQualifiedErrorId : [ERROR] DSC Module only supports ArcGIS Enterprise 10.7.x and later versions.
I tried to install version 10.8.1 and i'm sure that i imported an updated module
so please if you can support me or you have met error like this, your reply will be appreciated.
the script file is attached
