I have a fresh install of ArcGIS Server 10.7 Linux and I'm getting this error when I try to create a site through the Server Manager web interface.
All the threads I've read about this seem to indicate it's a license issue. I've tried Authorizing with a .prvc file through both the command line tool and the GUI and both methods display successful completion messages at the end. I've also tried stopping the server, deleting the keycodes file, re-authorizing, and starting the server.
When I check the Authorization status:
tools/authorizeSoftware -s
Starting the ArcGIS Software Authorization Wizard
Run this script with -h for additional information.
Product Ver ECP# Expires
arcsdeserver 107 ecp######### 28-aug-2019
datareviewersvr 107 ecp######### 28-aug-2019
highwayssvr 107 ecp######### 28-aug-2019
jtxserver 107 ecp######### 28-aug-2019
networkserver 107 ecp######### 28-aug-2019
svradv 107 ecp######### 28-aug-2019
svradv_4 107 ecp######### 28-aug-2019
svrenterprise 107 ecp######### 28-aug-2019
utilnetworksvr 107 ecp######### 28-aug-2019
In the server log I see:
<Msg time="2019-04-10T08:41:59,338" type="INFO" code="7252" source="Admin" process="10606" thread="1" methodName="" machine="myMachine" user="" elapsed="" requestID="">Creating a new site.</Msg>
<Msg time="2019-04-10T08:41:59,339" type="INFO" code="7064" source="Admin" process="10606" thread="1" methodName="" machine="myMachine" user="" elapsed="" requestID="">Checking and validating server licenses.</Msg>
<Msg time="2019-04-10T08:41:59,339" type="INFO" code="7241" source="Admin" process="10606" thread="1" methodName="" machine="myMachine" user="" elapsed="" requestID="">Server license check was successful.</Msg>
<Msg time="2019-04-10T08:41:59,339" type="FINE" code="7510" source="Admin" process="10606" thread="1" methodName="" machine="myMachine" user="" elapsed="" requestID="">Time elapsed in 'License' module is '0 millis (~ 0 minutes)'.</Msg>
<Msg time="2019-04-10T08:42:01,40" type="SEVERE" code="6533" source="Admin" process="10606" thread="1" methodName="" machine="myMachine" user="" elapsed="" requestID="">Failed to create the site. com.esri.arcgis.discovery.servicelib.AGSException:
Failed to register the activation group.</Msg>
I can't really tell if my software authorization was successful or not. What is the authorization status supposed to look like? Should I have a line for arcgisserver in there? Or is the software properly licensed/authorized and this issue related to something else entirely?
EDIT: I just tried re-installing and re-authorizing ArcGIS Server after stopping both firewalld and iptables services with the same results.
