I have worked a ton with web maps/feature layers and configuring them for offline use in ArcGIS Online, but now I am trying to do the same within our Enterprise environment and I'm a little stuck.
Hopefully I'm understanding the terminology correctly...we have parcel data stored on our SDE ("ArcGIS Server feature layer (feature service)") - NOT a hosted feature layer. These services are versioned.
I can access these services in ArcGIS Server Manager and I confirmed the following settings:
Based on what I've read in the documentation, it was my understanding that if a service had sync enabled, then it could be used offline. However, when I add this layer to a web map and then go to the settings page for the web map there is no option to enable it for offline use.
Is there some other step I'm missing to be able to use these layers offline?
Thanks in advance!
Best,
Katie
“The goal is not simply to ‘work hard, play hard.’ The goal is to make our work and our play indistinguishable.”
- Simon Sinek
