Hello all
We have a gp service that runs Visibility.
It gets a point layer (not interactive) and some other numeric parameter (such as radius).
We see a little different in results when we use the same point layer from ArcMap (using the service) or from WebMap.
Since it is exactly the same parameters it should be exactly the same.
Running from webmap or translating the file into JSON and running it from REST give the same results.
What can be the reason for this? Is it possible that when you call the service from soap (From ArcMap) the parameters are a little different?
