Dissolving the "shared" outline symbology in polygons in Map Viewer (enterprise)
549
12-14-2022 02:33 AM
LarsElmkær_Chwastek
Hi all,
I have a point layer, where I have set up attribute rules which create a polygon circle (in another layer) around the point with a specified radius.
Now my issue is that I would like to "dissolve" the outline that is shared between the different polygons to create, what is essentially, a buffer polygon symbology, where the outler outline is still visible, but the inner is not.
I have to create all my "buffer polygons" in the same layer, that's why I'm not using regular buffers.
Is there a way to achieve this symbology with either more attribute rules or maybe some other way?
Thanks 🙂
