I have a distributed collaboration set up between ArcGIS Enterprise and ArcGIS Online. The collaboration is currently synchronizing 16 feature layers as copies.
I am seeing frequent failures with the collaboration syncing one or more layers. The Collaboration Sync Status area of /portal/sharing/rest currently looks like this:
Digging in to one of the "completed_with_failures" records, I see messages like this:
"taskStatusId": "9f50f1eba2404a04a61df6f351163539",
"results": {
"succeededCount": 15,
"failedCount": 1,
"notProcessedCount": 0
"failed": [{
"itemId": "823cac5574374d7d840e77eb67580ba8",
"itemTitle": "Base_Parcel_Collaboration",
"message": "Failed to export item '823cac5574374d7d840e77eb67580ba8' into a replication package : 'Exporting item failed'"
"notProcessed": [],
"created": 1709654574646
Looking at the "completed_with_failures" errors, it appears that it is not always the same layer that causes the issue. In many cases it's a parcel layer that isn't changing anyway.
I increased the log levels for both Portal and Server to DEBUG and found entries similar to this in the portal logs:
Failed to synchronize replica. Failed to synchronize a replica on hosted feature layer 'https://gis.<redacted>.com/server/rest/services/Distributed_Collaboration/Base_Parcel_Collaboration/FeatureServer'. {"resultUrl":"","replicaName":"","submissionTime":1709653058000,"lastUpdatedTime":1709653067000,"status":"Failed","error":{"code":408,"description":"SyncTools service error.(null)"}}. Failed to synchronize a replica on hosted feature layer 'https://gis.<redacted>.com/server/rest/services/Distributed_Collaboration/Base_Parcel_Collaboration/FeatureServer'. {"resultUrl":"","replicaName":"","submissionTime":1709653058000,"lastUpdatedTime":1709653067000,"status":"Failed","error":{"code":408,"description":"SyncTools service error.(null)"}}
So it looks like the sync service is having an issue with...something(?), but I'm not sure where else to look. Hoping someone here has an idea on where to look / what to try to track down these intermittent errors.
Additional details:
ArcGIS Enterprise 11.1.0, fully patched
Geodatabase is running on SQL Server 2019 in AWS RDS
Collaboration is syncing 16 feature services as copies. Each service contains a single layer from the geodatabase.
Sync issue is intermittent between layers, but the most frequent errors appear to be with the parcel layers.
Thanks!
