Editing the Attributes of a feature Programmatically
4054
09-19-2014 01:23 PM
JessicaLott
New Contributor III
I have a feature layer with features that I would like to update programmatically. Below is my code:
        private void EditQueryTask_ExecuteCompleted(object sender, ESRI.ArcGIS.Client.Tasks.QueryEventArgs args)
            try
                if (txtServiceType.Text.Contains("Water") || txtServiceType.Text.Contains("WATER"))
                    FeatureLayer fl = MyMap.Layers["Meters"] as FeatureLayer;
                    List<int> deletedServiceOrders = new List<int>();
                    FeatureSet fs = args.FeatureSet;
                    fs.Features[0].Attributes["PWSID"] = txtMeterNumber.Text;
                    fs.Features[0].Attributes["CIS_METR"] = txtAccountNumber.Text;
                    fs.Features[0].Attributes["CUSTYPE"] = txtCustType.Text;
                    fs.Features[0].Attributes["STR"] = txtStreet.Text;
                    fs.Features[0].Attributes["CITY"] = txtCity.Text;
                    fs.Features[0].Attributes["COMMENTS"] = txtName.Text;
                    fl.SaveEdits();
                    fl.Update();
                    DeleteServiceOrder.Visibility = Visibility.Collapsed;
                    fl.EndSaveEdits += featurelayerSO_EndSaveEdits;
                    fl.SaveEditsFailed += featurelayerSO_SaveEditsFailed;
            catch (Exception e)
                MessageBox.Show(e.Message);
Everything is being set correctly and there are no errors, but the values are not actually being saved into ESRI. I am thinking it has something to do with nothing has ever actually be edited? I know I am missing something. Any help would be appreciated!
MichaelBranscomb
Esri Frequent Contributor
I suggest taking a look at the Dev Summit examples: http://www.arcgis.com/home/item.html?id=3f69c79bbd7340b09fad396647a977a5
Specifically the Editing-Stand-Alone-Tables example.
Cheers
Mike
JaredStewart
Hi Jessica,
If your feature layer is being hosted with Feature Access on ArcGIS Server, you could try something like this:
     try
               var myServiceUrl = ""; // Enter your service URL here (Ex: http://myAGS:6080/arcgis/rest/services/myService/FeatureServer/ )
               var featureString = String.Format(
                   "[{{\"id\":0, \"updates\": [{{" +
                         "\"geometry\":{{\"x\":{0},\"y\":{1}}}," +
                         "\"attributes\":" +
                               "\"PWSID\":{2}," +
                               "\"CIS_METR\":{3}," +
                               "\"CUSTYPE\":{4}," +
                               "\"STR\":{5}," +
                               "\"CITY\":{6}," +
                               "\"COMMENTS\":{7}," +
                   fs.Features[0].geometry.X,
                   fs.Features[0].geometry.Y,
                   txtMeterNumber.Text,
                   txtAccountNumber.Text,
                   txtCustType.Text,
                   txtStreet.Text,
                   txtCity.Text,
                   txtName.Text
             var parameters = "edits=" + HttpUtility.UrlEncode(featureString) + "&f=pjson";
             var wc = new WebClient();
             wc.headers["Content-Type"] = "application/x-www-form-urlencoded";
             wc.Encoding = Encoding.UTF8;
             wc.UploadStringCompleted += (sender, e) =>
                          if (e.Error == null)
                              var responseString = e.Result;
                              if (responseString.contains("\"success\": true"))
                                   MessageBox.Show("Successfully updated.");
                              else
                                   MessageBox.Show("ERROR: " + responseString);
                         else
                             MessageBox.Show("ERROR: " + e.Error.Message);
               wc.UploadStringAsync(new Uri(myServiceUrl + "/applyEdits"), "POST", parameters);
     catch (Exception e)
The code will probably need some tweaking to fit your needs, but this is roughly what I've been using to update features programmatically.
