I use a process to reconcile all the versions. For some reason it never finalizes succesfully. When the process is running at some point i will get the following error message: Error reconciling version DAVAZQUEZ.722384_JTX.[Out of server memory [SDE.GDB_ItemRelationships]].
I got this message afte the process reconciled more than 220 versions. It does not matter if I reconcile by objects or attributes, i get the same error. If I restart the proccess it finishes successfully but if I have more than 220 versions it will fail.
My database is 10.2.0 and Desktop 10.2.0. The process runs before people start working or after hours,when nobody is using it.
Please any help will be appreciated
Diego Llamas
