I have added XY data from a table named ???student??? and I can display XY points on the ArcMap 10.1.
But I failed publishing the map to my spatial data server.
Actually, everything is fine. I can Analyze with no error or warning, I can preview the map, but when I click Publish, the below error occurs:
???Packaging succeeded, but publishing failed???
???ERROR: code:400,, Table ???DBO.%Student_Features??? was not found in the datasource., Bad syntax in request.???
???Please consult the GP Results Windows for enhanced error description.???
Please advise.
Thank you for your helps,
Pongthep
