Hello There,
We have been using this ArcGIS Server for years. Now, when i restarted windows server hosting ArcGIS Server, the URL unexpectedly took me to ArcGIS Server setup wizard.
Before restarting the server i successfully updated arcgiscache, arcgisjobs, arcgisoutput & arcgissystem directories location. Using ArcGIS manager i updated these directories from one network location to another.
Below are content of two ArcGIS Server logs
<Msg time="2018-10-28T08:11:49,463" type="WARNING" code="9026" source="Rest" process="4636"
thread="13" methodName="" machine="ABC1.XYZ.LOCAL" user="" elapsed="">ArcGIS Server Site is not
initialized. Error creating object to be cached: com.esri.discovery.app.security.DiscoverySecurity
</Msg>
<Msg time="2018-10-28T08:11:49,465" type="SEVERE" code="9003" source="Rest" process="4636" thread="13"
methodName="" machine="ABC1.XYZ.LOCAL" user="" elapsed="">Unable to process request. ArcGIS Server
Site is not configured. Check with your ArcGIS Server administrator for resolution;
an ArcGIS Server site is created or machines are added to an existing site using ArcGIS Server Manager.
</Msg>
<Msg time="2018-10-25T16:04:34,256" type="SEVERE" code="6649" source="Admin" process="3492" thread="1"
methodName="" machine="ABC1.XYZ.LOCAL" user="" elapsed="">Unexpected error while cleaning
arcgisjobs server directory. String index out of range: -1</Msg>
Kindly suggest.
Environment:
Windows Server 2012 R2
ArcGIS Server 10.2 : Federated
Thanks for all support
- AS
