Original User: JillPenney
Hi Ethan,
A few things to check:
-@ the service level:
-service properties: ensure create is checked on for operations allowed
-are you able to perform other edits such as update or delete data?
-@ the data level:
-does the feature class have an Esri ObjectID or an auto-incrementing id field?
-are you able to edit this feature class in ArcMap?
-does the user have the proper permissions to edit the data?
-also, which DBMS are you using?
-Jill
