Maybe you can point me in the right direction on this. So I have the python script running and I added the script to the tool box. the problem is that I need to be able to have the user enter the First_point and then end_point. when I run the script through the tool box it says this tool has no parameters. Here is the working python script.
# -*- coding: utf-8 -*-
# new_seg4.py
# Created on: 2015-10-29 07:32:00.00000
# (generated by ArcGIS/ModelBuilder)
# Usage: new_seg4 <first_point> <end_point> <first_point__2_> <end_point__3_> <beg_point> <end_pt> <first_pt_loc> <end_pt_loc> <points> <segment> <temp__2_>
# Description:
# Import arcpy module
import arcpy
toolbox = ("E:/MDTAPPS/interactive/refmseg.tbx")
# Load required toolboxes
arcpy.ImportToolbox("E:/MDTAPPS/interactive/refmseg.tbx")
# Script arguments
first_point = arcpy.GetParameterAsText(0)
if first_point == '#' or not first_point:
first_point = "E:\\MDTAPPS\\interactive\\interactive.mdb\\first_point" # provide a default value if unspecified
end_point = arcpy.GetParameterAsText(1)
if end_point == '#' or not end_point:
end_point = "E:\\MDTAPPS\\interactive\\interactive.mdb\\end_point" # provide a default value if unspecified
first_point__2_ = arcpy.GetParameterAsText(2)
if first_point__2_ == '#' or not first_point__2_:
first_point__2_ = "E:\\MDTAPPS\\interactive\\interactive.mdb\\first_point" # provide a default value if unspecified
end_point__3_ = arcpy.GetParameterAsText(3)
if end_point__3_ == '#' or not end_point__3_:
end_point__3_ = "E:\\MDTAPPS\\interactive\\interactive.mdb\\end_point" # provide a default value if unspecified
beg_point = arcpy.GetParameterAsText(4)
if beg_point == '#' or not beg_point:
beg_point = "beg_point" # provide a default value if unspecified
end_pt = arcpy.GetParameterAsText(5)
if end_pt == '#' or not end_pt:
end_pt = "end_pt" # provide a default value if unspecified
first_pt_loc = arcpy.GetParameterAsText(6)
if first_pt_loc == '#' or not first_pt_loc:
first_pt_loc = "E:\\MDTAPPS\\interactive\\interactive.mdb\\first_pt_loc" # provide a default value if unspecified
end_pt_loc = arcpy.GetParameterAsText(7)
if end_pt_loc == '#' or not end_pt_loc:
end_pt_loc = "E:\\MDTAPPS\\interactive\\interactive.mdb\\end_pt_loc" # provide a default value if unspecified
points = arcpy.GetParameterAsText(8)
if points == '#' or not points:
points = "E:\\MDTAPPS\\interactive\\interactive.mdb\\points" # provide a default value if unspecified
segment = arcpy.GetParameterAsText(9)
if segment == '#' or not segment:
segment = "segment" # provide a default value if unspecified
temp__2_ = arcpy.GetParameterAsText(10)
if temp__2_ == '#' or not temp__2_:
temp__2_ = "E:\\MDTAPPS\\interactive\\interactive.mdb\\temp" # provide a default value if unspecified
# Local variables:
Output_Event_Table_Properties = "RID POINT MEAS"
Output_Event_Table_Properties__2_ = "RID POINT MEAS"
MDTGIS_ROUTES_LRM_RM = "MDTGIS.ROUTES_LRM_RM"
MDTGIS_ROUTES_LRM_DC_MI = "MDTGIS.ROUTES_LRM_DC_MI"
MDTGIS_ROUTES_LRM_DC_MI__2_ = "MDTGIS.ROUTES_LRM_DC_MI"
interactive_mdb = "E:\\MDTAPPS\\interactive\\interactive.mdb"
MDTGIS_ROUTES_LRM_DC = "MDTGIS_ROUTES_LRM_DC"
temp = "E:\\MDTAPPS\\interactive\\interactive.mdb\\temp"
# Process: Calculate Field
arcpy.CalculateField_management(first_point, "Corridor", "str(!Corridor!) + \"_\" + str(!RM!)", "PYTHON_9.3", "")
# Process: Calculate Field (2)
arcpy.CalculateField_management(end_point, "Corridor", "str(!Corridor!) + \"_\" + str(!RM!)", "PYTHON_9.3", "")
# Process: Make Route Event Layer (2)
arcpy.MakeRouteEventLayer_lr(MDTGIS_ROUTES_LRM_RM, "ROUTE_ID", end_point__3_, "Corridor POINT end_offset", end_pt, "", "ERROR_FIELD", "NO_ANGLE_FIELD", "NORMAL", "ANGLE", "LEFT", "POINT")
arcpy.MakeRouteEventLayer_lr(MDTGIS_ROUTES_LRM_RM, "ROUTE_ID", first_point__2_, "Corridor POINT beg_offset", beg_point, "", "ERROR_FIELD", "NO_ANGLE_FIELD", "NORMAL", "ANGLE", "LEFT", "POINT")
# Process: Locate Features Along Routes
arcpy.LocateFeaturesAlongRoutes_lr(beg_point, MDTGIS_ROUTES_LRM_DC_MI, "CORRIDOR", "0 Meters", first_pt_loc, Output_Event_Table_Properties, "ALL", "NO_DISTANCE", "ZERO", "NO_FIELDS", "NO_M_DIRECTION")
# Process: Locate Features Along Routes (2)
arcpy.LocateFeaturesAlongRoutes_lr(end_pt, MDTGIS_ROUTES_LRM_DC_MI__2_, "CORRIDOR", "0 Meters", end_pt_loc, Output_Event_Table_Properties__2_, "FIRST", "NO_DISTANCE", "ZERO", "NO_FIELDS", "NO_M_DIRECTION")
# Process: Append
arcpy.Append_management("E:\\MDTAPPS\\interactive\\interactive.mdb\\first_pt_loc;E:\\MDTAPPS\\interactive\\interactive.mdb\\end_pt_loc", temp, "", "RID \"CORRIDOR\" true true false 10 Text 0 0 ,First,#,E:\\MDTAPPS\\interactive\\interactive.mdb\\first_pt_loc,RID,-1,-1,E:\\MDTAPPS\\interactive\\interactive.mdb\\end_pt_loc,RID,-1,-1;beg_offset \"beg_offset\" true true false 8 Double 0 0 ,First,#;end_offset \"end_offset\" true true false 8 Double 0 0 ,First,#", "")
# Process: Table to Table
arcpy.TableToTable_conversion(temp__2_, interactive_mdb, "points", "", "RID \"CORRIDOR\" true true false 10 Text 0 0 ,First,#,E:\\MDTAPPS\\interactive\\interactive.mdb\\temp,RID,-1,-1;beg_offset \"beg_offset\" true true false 8 Double 0 0 ,First,#,E:\\MDTAPPS\\interactive\\interactive.mdb\\temp,beg_offset,-1,-1;end_offset \"end_offset\" true true false 8 Double 0 0 ,First,#,E:\\MDTAPPS\\interactive\\interactive.mdb\\temp,end_offset,-1,-1", "")
# Process: Make Route Event Layer (3)
arcpy.MakeRouteEventLayer_lr(MDTGIS_ROUTES_LRM_DC, "CORRIDOR", points, "rid LINE beg_offset end_offset", segment, "", "ERROR_FIELD", "NO_ANGLE_FIELD", "NORMAL", "ANGLE", "LEFT", "POINT")
# Process: Script1
arcpy.Script1_ref()
