Environment: ArcGIS Pro 3.2.1, ArcGIS Enterprise 11.1
I published a geoprocessing tool which converts AutoCAD .dwg file to .geojson format.
When i try to run it from WebApp Builder or Portal Map viewer classic, It throughs below error.
It worked fine on ArcGIS Pro desktop, with no issues
Traceback (most recent call last): File "", line 99, in execute File "C:\Program Files\ArcGIS\Server\framework\runtime\ArcGIS\Resources\ArcPy\arcpy\conversion.py", line 2169, in CADToGeodatabase raise e File "C:\Program Files\ArcGIS\Server\framework\runtime\ArcGIS\Resources\ArcPy\arcpy\conversion.py", line 2166, in CADToGeodatabase retval = convertArcObjectToPythonObject(gp.CADToGeodatabase_conversion(*gp_fixargs((input_cad_datasets, out_gdb_path, out_dataset_name, reference_scale, spatial_reference), True))) File "C:\Program Files\ArcGIS\Server\framework\runtime\ArcGIS\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 512, in return lambda *args: val(*gp_fixargs(args, True)) arcgisscripting.ExecuteError: Failed to execute. Parameters are not valid. ERROR 000732: Output Geodatabase: Dataset
C:\Users\PRODGI~1\AppData\Local\Temp\tmp2vw9kb42
\\networkfiles\location\arcgisserver\directories\arcgissystem\arcgisinput\others\Tool1.GPServer\extracted\p30\..\cd\shapefile_datatemp.gdb does not exist or is not supported Failed to execute (CADToGeodatabase). Failed to execute (DWGtoGEOJSON_Stage1). Failed.
# -*- coding: utf-8 -*-
import arcpy
import os
import tempfile
import os.path
import shutil
class Toolbox:
def __init__(self):
"""Define the toolbox (the name of the toolbox is the name of the
.pyt file)."""
self.label = "toolbox"
self.alias = "toolbox"
# List of tool classes associated with this toolbox
self.tools = [Tool]
class Tool:
def __init__(self):
"""Define the tool (tool name is the name of the class)."""
self.label = "DWGtoGEOJSON_Stage1"
self.description = ""
def getParameterInfo(self):
"""Define the tool parameters."""
params = [
arcpy.Parameter(displayName="Input_CAD_File",
name="in_cad",
datatype="DEFile",
parameterType="Required",
direction="Input"),
arcpy.Parameter(displayName="Output GEOJSON File",
name="out_geojson",
datatype="DEFile",
direction="Output")
return params
def isLicensed(self):
"""Set whether the tool is licensed to execute."""
return True
def updateParameters(self, parameters):
"""Modify the values and properties of parameters before internal
validation is performed. This method is called whenever a parameter
has been changed."""
return
def updateMessages(self, parameters):
"""Modify the messages created by internal validation for each tool
parameter. This method is called after internal validation."""
return
def execute(self, parameters, messages):
"""The source code of the tool."""
in_cad = parameters[0].valueAsText
out_geojson = parameters[1].valueAsText
temp_dir = tempfile.mkdtemp()
temp_gdb = "temp.gdb"
arcpy.CreateFileGDB_management(temp_dir, temp_gdb)
arcpy.env.workspace = os.path.join(temp_dir, temp_gdb)
# Execute Create FileGDB, temp
# Process: CAD to Geodatabase
arcpy.CADToGeodatabase_conversion(in_cad, temp_dir+'//'+temp_gdb, "FClass", "1000", "GEOGCS['GCS_WGS_1984',DATUM['D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]];-400 -400 11258999068426.2;-1073.7418235 4194304001953.12;-100000 10000;8.98315284119522E-09;0.001;0.001;IsHighPrecision")
# Process: Iterate Feature Classes
datasets = arcpy.ListDatasets(feature_type='feature')
datasets = [''] + datasets if datasets is not None else []
for ds in datasets:
for fc in arcpy.ListFeatureClasses(feature_dataset=ds):
path = os.path.join(arcpy.env.workspace, ds, fc)
print(path)
arcpy.FeaturesToJSON_conversion(fc, out_geojson, "FORMATTED", "NO_Z_VALUES", "NO_M_VALUES", "GEOJSON")
# Process: Features To JSON
## arcpy.FeaturesToJSON_conversion(fc, out_geojson, "FORMATTED", "NO_Z_VALUES", "NO_M_VALUES", "GEOJSON")
# Execute Delete FileGDB
#arcpy.Delete_management(newpath)
## return
def postExecute(self, parameters):
"""This method takes place after outputs are processed and
added to the display."""
return
Hey @User35489
Looking through the error message and through the code you provided, I believe that it works through the Desktop application due to the program being able to create a gdb through the local PC. It may be experiencing roadblocks due to running through an online service unable to create certain files.
In my opinion, I'd first attempt to place some print or return functions throughout that show what certain data is, and also keep the File Explorer open to observe the creation of the gdb. I imagine there is a step that is occurring that isn't hit at all, specifically maybe this here:
Isn't being created possibly?
Hope it points you in the right direction!
Cody
