Hi all,
I am currently working with ArcGIS Pro version 3.0 and ArcGIS Server 10.9.1 that is federated to a Portal site.
I am trying to publish a geoprocessing tool from ArcGIS Pro ("Reconcile Versions") to my portal so that I can call it as a GP service in workflow manager server.
The problem that I'm facing right now is that the parameter "Input Workspace" does not get published together with the rest of the tool's parameters (Target version, Edit version, etc...). For context, my input workspace is the published feature service URL that is being used in my branch versioning editing workflow.
Also, when I checked if I could configure the "Input Workspace" parameter in the Share Web Tool contents tab, the option to edit the parameter is disabled/greyed out because ArcGIS Pro has determined it is a constant value (see attached image). I assume that this is why the parameter is not being published compared to the others. However, I see no way for it to be amended to a user-input and it is just stuck at a constant value.
My question is: How can I get this "input workspace" parameter published with the other parameters when I am sharing the Reconcile Versions GP tool as a web tool so that the parameter is visible to the user when I call it as a GP service?
Thanks for reading!
- Eva
