Adrian Welsh wrote: But, to be clear, are you saying you use the computer's name as opposed to the computer's IP address in place of "<machine>"? |
Yes, the machine/computer name and the port for both the admin and manager. At least on our network, I would get an error when using the ip....my guess is it is due to the SSL certificate. As for my mentioning the web adaptor not working, that is by design, (recommended for security) that is, I have that disabled on purpose, so to manage, I have to be within our domain (although VPN remote works, since that gets me into the domain).
i noticed that you have site.html in your post....I doubt that is the issue, but you might try without.
also, for kicks, try it with http and :6080 My guess is it knows you should be https, and would definitly be need isf you have security enabled, but it's been a while since I did the install (but hope to test 10.4.1 very soon). and if you do have security in place, do you have a SSL installed? Self signed? Seems like I had to have all that, but again, been awhile and our production is still 10.2.2.
hope it works....and of course, I'm sure you know you can always do many of the things thru Catalog on any machine...just not the true admin stuff (logs, security, etc).
