How to consume Civil3D cogo points as Point Feature service in SDE
410
01-30-2019 09:45 PM
Roshankumar
Hi ,
We’ve a Technical requirement related to ArcGISforAutoCAD.‌
Requirement is : To consume Civil3D cogo points as Feature service in SDE and using the ArcGIS for AutoCAD plugin same feature service points need to edit in #Civil3D environment and synchronized to same feature service that save in SDE.
And Same Feature service need to edit in ESRI platform (Portal /Desktop)  as Point Feature class,
in all case (single data source i.e Point Feature Service in SDE).
Please could you help to understand so solution, is this requirement is feasible ?
Looking forward with your expert solution.
Many thanks,
Roshan
Tags (1)
