insert into sql table from geoprocessing service
1433
10-15-2014 11:01 AM
DorothyMortenson
Occasional Contributor II
Hello.
I have a geoprocessing service that kicks off a python script.
In that python script:
  • make a map
  • take the map as a png file and insert it into a sql table
Python script works fine on the server.
Python script works fine as a custom ArcTool.
So I create a geoprocessing service. It fails.
I have stripped the code down to just the insert.  It appears I can insert into the sql table as long as I do not include the map.  but if I do, it does not work in the geoprocessing service. I thought it might be a pathname issue, so I tried putting the png in the same directory as the script.
Here is the code:
import pypyodbc
rec_creation_userid = '1234'
wl_id = 99
mime_type = 'image/png'
map_file_name = '99.png'
# tried with pathname - does NOT work in gp service
well_location_map = 'C:\\pathname\\maps\\99.png'
# tried with null- does  work in gp service
well_location_map= ""
# tried with no pathname - does NOT work in gp service
well_location_map = '99.png'
parameters = rec_creation_userid, wl_id, mime_type, map_file_name, well_location_map
cnxn = None;
cnxn = pypyodbc.connect('DRIVER={SQL Server Native Client 10.0};SERVER=myserver\\AAAA;DATABASE=database;UID=username;PWD=password')
cursor = cnxn.cursor()
#==== uses a stored procedure for the insert=======
sp = "set nocount on ; "
sp = sp + "DECLARE @return_value int; "
sp = sp + "DECLARE @new_serial_id int; "
sp = sp + "DECLARE @return_msg varchar(250); "
sp = sp + "exec    @return_value = dbo.wrd_wl_pend_map_attachment_insert @new_serial_id OUTPUT, \
    @return_msg OUTPUT, \
    @current_userid = ?, \
    @wl_id = ?, \
    @mime_type = ?, \
    @map_file_name = ? , \
     @map_attachment = ?  "
sp = sp + "select @return_value as return_value, @new_serial_id as new_serial_id, @return_msg as return_msg ; "
cursor.execute(sp, parameters)
row = cursor.fetchone()
if (row[0] > 0):
    logfile.write("There was an error: " + str(row[0])  + "\n\n")
print row
cursor.close()
cnxn.commit()
cnxn.close()
