java processes not running in 10.1 and 10.1 SP1
5814
12
04-02-2013 11:15 PM
ChristopherMugdan
We recently moved premises and moved our network to a new IP address running 10.1. When I re-started the machine the service were not running, but I could get to the manager. When I re-started ArcGIS Server, I could no longer gain access to the manager or services.
I uninstalled 10.1 and installed 10. SP1 from scratch. I did keep my \arcgisserver directory from when the machine had a different IP address (but the same name) though.
When I start the ArcGIS Server, the two java processes do not start, but the ArcGIS Server process starts. I cannot find any logs that tell me what the problem is.
Chris Mugdan
LorenCress
I had the same issue when upgrading.  I also tried uninstalling and reinstalling, with no joy.  What I eventually discovered was that the log (C:\Program Files\ArcGIS\Server\framework\etc\service\logs\service.log) was saying (upon startup):
Found flag file C:\Program Files\ArcGIS\Server\framework\etc\upgrade.txt. Starting in upgrade mode.
So I renamed that file to upgrade.txt.old, restarted ArcGIS Server, and voila! Manager and admin page suddenly worked.  Problem solved.
I don't know why it wasn't starting, but that at least got me to a fresh, functional installation.
TerryGiles
Thank you Loren, I just hit this today & same as you uninstall/reinstall did not work.  Renamed the upgrade.txt file restarted ArcGIS Server service and back in business!
MatthewLofgren
Holy cow... I've been pulling my hair out all day. Repairing, uninstalling, reinstalling... ahhh
I'm on 10.4.1 and the text file was called ArcGISServerUG.txt
I renamed that and restarted the service and now it works.. THANK YOU!!!
