I have added the esri world basemap as an item in my enterprise portal with saved credentials for arcgis online access. Then i have created a webmap and promoted as a basemap that i can use.
On this basemap, i am trying to run manage map area and i am getting this error
{"paramName":"packages","dataType":"GPString","value":[{"source": "https://portal.orgdomain.com/portal/sharing/servers/ff781621fb824b918c078d0c5bb7d15b/rest/services/World_Basemap_Export_v2/VectorTileServer", "error": "{\"code\": 4, \"messageCode\": \"OffPkg_ 4\", \"message\": \"Failed to get status for item 7da84d730cb64f0fa438fc4faa7581bd error Error in adding url file item \", \"params\": {\"itemId\": \"7da84d730cb64f0fa438fc4faa7581bd\", \"error\": \"Error in adding url file item \"}}", "itemId": "7da84d730cb64f0fa438fc4faa7581bd"}]}
we don't have any firewall issue, atleast it does not look like that. Any idea what it could be?
I also have support ticket with esri, no luck so far.
this issue was resolved by adding some domains through firewall exceptions, particular there would be one for the datastore hosted in aws, if you are using esri basemaps for creating offline areas.
