I have 2 questions concerning WMS services.According to the documentation Image Services should be OGC compliant for WMS.http://ags-sdi.jrc.it:6080/arcgis/help/en/index.html#//015400000411000000I have the following problem: I created an Image service and got the capabilities which are automatically generated by a GetCapabilities Request.If I validate the generated xml file, I see the following problems:Unable to locate a reference to a supported schema type (DTD, W3C Schema) within this document instance.The solution is to substitute this part<WMS_Capabilities version="1.3.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://schemas.opengis.net/wms/1.3.0/capabilities_1_3_0.xsd">
with<WMS_Capabilities version="1.3.0"
xsi:schemaLocation="http://www.opengis.net/wms http://schemas.opengis.net/wms/1.3.0/capabilities_1_3_0.xsd"
xmlns="http://www.opengis.net/wms">
After this correction there is another error:<GetStyles>
<Format>application/vnd.ogc.sld+xml</Format>
<DCPType>
<HTTP><Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://ags-sdi.jrc.it:6080/arcgis/services/Danube_Test_IS/ImageServer/WMSServer"/></Get></HTTP>
</DCPType>
</GetStyles>
Element <GetStyles> is not allowed under element <Request>.
Reason: The following elements are expected at this location (see below)
<wms:GetFeatureInfo>
Error location: WMS_Capabilities / Capability / Request / GetStylesAfter cutting off the GetStyles section the xml file is valid.If I create the service as a map service the xml from the GetCapabilities Request is fine. Is this a problem of ArcGIS Server and will it be resolved ?___________________________________________________________Second question:I encountered the following problem with the map service SampleWorldCities xml from the GetCapabilities Request and also for other services. How can this be fixed ?Value '180.000122' is not allowed for element <eastBoundLongitude>.
Reason: Value '180.000122' violates 'maxInclusive' facet value '180'.
Error location: WMS_Capabilities / Capability / Layer / EX_GeographicBoundingBox / eastBoundLongitude
Details
cvc-maxInclusive-valid.1: For type definition 'wms:longitudeType' the value '180.000122' is not numerically less than or equal to its 'maxInclusive' facet value '180'.
cvc-datatype-valid.2: The value '180.000122' is not a member of type definition 'wms:longitudeType'.
cvc-simple-type.1: For type definition 'wms:longitudeType' the string '180.000122' is not valid.
cvc-type.3.1.3: The normalized value '180.000122' is not valid with respect to the type definition 'wms:longitudeType'.
cvc-elt.5.2.1: The element <eastBoundLongitude> is not valid with respect to the actual type definition 'wms:longitudeType'.extract of xml:<EX_GeographicBoundingBox><westBoundLongitude>-180.000000</westBoundLongitude><eastBoundLongitude>180.000122</eastBoundLongitude><southBoundLatitude>-90.000000</southBoundLatitude><northBoundLatitude>90.000122</northBoundLatitude></EX_GeographicBoundingBox>
How can I set this automatically created values in the right way and where (in ArcMap) ?Thanks for your help.Hilde
