Organization URL for Enterprise for Collaboration
257
8
3 weeks ago
Tammira
I am trying to set up a partnered collaboration between my AGOL and Enterprise.  I can't seem to get the correct URL for my enterprise orgnaztion to enter into the box to set up the collaboration from AGOL. I tried the portal homepage, tried removing the web adaptor number.  I'm not having any luck.  Where do I find the right URL to input into the AGOL collaboration box?
Also, will a collaboration work for local domain deployment?
TYIA!
Tammira
Thank you, Henry. I suspected that the .local DNS would be an issue.  Thank you for your response!
MichaelJenkins
Isn't a Partnered Collaboration only for ArcGIS Online to ArcGIS Online?    Use a Distributed Collaboration for Enterprise to ArcGIS Online.
 Understand collaborations—ArcGIS Online Help | Documentation
GISP
Tammira
I was reading somewhere that you could use a partnered collaboration, but a distributed might be a better option.  Thank you for your help!
MichaelJenkins
With a Distributed Collaboration between Enterprise and ArcGIS Online, the Enterprise Portal can be behind a firewall on a local DNS because Enterprise connects to Online, but Online never connects to Enterprise.
GISP
Tammira
Thank you, Michael! With a distributed collaboration would I be able to share data from AGOL to a .local DNS Enterprise portal?
MichaelJenkins
Yes, and AGOL doesn't need to be able to communicate directly with the Portal.   The Portal will reach out to AGOL and ask for the data.
GISP
Tammira
Perfect!  Thank you so much for your advice!
HenryLindemann
Hi @Tammira, the URL you are looking for has to be specified like this https://dns.com/webadaptor but your system needs to be public facing and needs to have a valid public URL e.g. no .local DNS and a public certificate.
Regards
Henry
Tammira
