We have a SSL certficate signed by a CA and I'm trying to use Cloud Builder on Amazon Web Services to add the certificate to the instance we want to create. My problem is that I can't find/locate the private key file that is associated with the certificate. I've found very little guidance on what to do and where to find it. Any help?
You can re-key it if needed.
I saw that but I can't use the DigiCert utility because I haven't created the server yet. Do I just create it on my local machine, but then where is the key file located?
