Hi Tom,
I have also stucked in similar issue as you mentioned here , can you please help me in getting out of it.
I am using Arcgis 10.2 with web adaptor. I am using LDAP users and built-in roles. Also, set up the proxy page to use authentication from my flex page while accessing the services.
Unfortunately , i am getting this error message :
Working View layer failed to load: Fault info: Unable to get token service url from (http://sgj-srv-pub/arcgis/rest/info) Version 10.01+ required.
Please help
Regards,
Saurabh
I just worked thru solving the web adapter problem this thread has described and solved. However, I found this thread after I solved it and thus wasted a bunch of time. I was using the wrong search criteria. For other folks trying to locate this solution I'm adding the following error message that others might be searching on:
Error: WEB_ADAPTOR Authentication, User Credential is not set by the web adaptor for this request, check if the web adaptor is secured
Code: 403
Let's hope the ESRI Forums search engine finds this post.
D. Geasan
