publish a model builder to export shapefile and/or gdb
799
04-25-2022 11:35 PM
GuillaumeArnaud
I need to publish a model builder to export shapefile and/or gdb on ArcGIS Server.
Data source is declare on ArcGIS Server. I need the result as a zip file.
So, I need to know :
- How will I declare a temp folder like in_memory to store temp shapefile and/or gdb ?
- How will I make a zip with this files or folder ?
- How will I send this zipfile to the user ? I think it's with using parameter or live something blank like print template but i didn't find any documentation to help me.
Thanks for your answeR.
Guillaume ARNAUD
DavidPike
MVP Frequent Contributor
If you have an arcmap install around somewhere Geoprocessing service example: Clip And Ship—ArcGIS Server | Documentation for ArcGIS Enterprise would be a good model to pick through as it produces a zip in model builder.
if you use %scratchfolder% in the model Managing intermediate (scratch) data in shared model and script tools—ArcMap | Documentation (arcgis... , on publishing, it will be repathed to a memory/scratch folder on arcgis server.
GuillaumeArnaud
Hi, is there something like that to extract and send some item from a table ?
I need to do this for a database with 3 entity class and 28 tables. Actually I have this thing but its in local :
This one call other function
This one clip geographical object and store it in gdb + shp
This one copy all table in the gdb + export it in multiple dbf
This one select entry which is needed in function of entityt selected and copy them in tables in the gdb + export it in multiple dbf
The result is something like that :
Thanks.
GuillaumeArnaud
thank you. I will try tomorrow.
