Query Server logs excluding a particular error code
395
12-23-2019 03:31 AM
GarethBaker1
Occasional Contributor III
Is there a way to exclude a particular error code from a query against ArcGIS Server either within Manager or via the Admin Directory?
I've read the REST admin help which describes all the different filters that can be applied but there is no mention of any operators that exclude particular codes (unless I'm missing something obvious here).  Looks like there is an option to provide a comma separated list of codes to filter for but I assume this list would be massive if I wanted to include every code except the one I don't want (in this case 104001)?!
GarethBaker1
I think I have managed to answer my own question.  Looks like you can provide a range of values e.g. 0-104000,104002-999999 will exclude code 104001.
