I'm moving webmaps from on-prem Enterprise to an Azure Enterprise site that we're migrating to. I need help with retrieving the webmap offline area properties, so the offline areas can be re-created on the target Enterprise site using:
webmap.offline_areas.create(area,item_properties)
I just can't figure out how to retrieve the offline area "area" property?
Here's what I have so far
wm = WebMap(source_item)
map_areas = wm.offline_areas.list()
if len(map_areas)>0:
for ma in map_areas:
print(ma.title)
print(ma.get_data())
Area1
{'mapAreas': {'mapAreaTileScale': {'minScale': 147914382, 'maxScale': 2500}, 'mapAreaRefreshParams': {'startDate': '2022-04-12T12:51:22.179Z', 'type': 'weekly', 'nthDay': 1, 'dayOfWeek': 2}, 'mapAreasScheduledUpdatesEnabled': False}}
But how do I access the area property of the offline area?
Here's how to retrieve the x,y extents of a webmap offline area:
source_wm = WebMap(source_item)
map_areas = source_wm.offline_areas.list()
offline_item_extent = ma.properties['extent']
