Reverse Proxy and SSL
2011
10-23-2013 06:29 AM
AlbertoAloe
Hi everybody.
I have a publicly exposed ArcGIS Server 10.2 running on a virtual machine in perimeter network (DMZ). OS is Windos server 2008 R2 with IIS 7.5 and I'm using web adaptor. IIS and ArcGIS server are set for http only.
I'd like to add a bit more of security putting SSL into place. My network guys proposed me to use a reverse proxy that is holding the signed certificate and then reroute the traffic to my webserver. The reverse proxy will handle the encripted https traffic forwarding http traffic to port 80 of my web server (flagging http header in order to inform the web werver of encryption-decryption).
Is this configuration OK? Somewhere I found an article that says that https should be implemented end to end.
Thanks
Alberto
GregoryHollard
New Contributor II
You have to do SSL end-to-end, otherwise ArcGIS Server returns the wrong URL back to the client for operations such as "Export Map" etc.
JasonPatterson
New Contributor III
AdrianMarsden
Occasional Contributor III
Hi - did you ever resolve this?  I'm trying to do similar
  • AGS and WA on same server
  • Public sub domain served by MS TMG reserve proxy firewall
  • We have a CA Cert for *.ourmaindomain.tld
  • We have a need to enable htpps on sub domain
I tried adding the CA Cert to AGS following instructions, but everything broke - I think I managed to get https access to our sub domain internally (so not going via TMG reverse proxy) but my Javascript API sites broke
Cheers
ACM
JohnMellor__GISP
New Contributor III
I'm trying to install ArcGIS for Server 10.4.1 - and am running into a certificate problem. I can see the manager URL from the server, but not from workstation (without going through Advanced and selecting the non recommended route).  Any suggestions?
RebeccaStrauch__GISP
Have you tried installing the web adaptor and accessing manager thru that URL?
About the ArcGIS Web Adaptor—Installation Guides (10.4.1) | ArcGIS for Server
Or just going in thru ArcCatalog?
