Server is not ready for publishing
4003
08-12-2015 08:53 AM
JohnChurchill
New Contributor III
Using 10.3 ArcGIS Server I still get the Error in my log file after seeing this dialog. Publishing worked yesterday with same map and same service. The only thing different is that I added a field to one layer.
From the log file ...
Method failed.HRESULT = 0x80070057 : The parameter is incorrect. .
And yes the Publishing Tools ARE running on the server making this a very non-useful error message.
JohnChurchill
New Contributor III
Workaround for today is save service definition (.sd) file, delete running service and replace. That seems to work.
JeffTimm
Anther work around for this issue is to go to your arcgisserver folder that contains the directories and the config store and search for .rlock files.  Once the search is complete select all and delete.
This has worked for me many times.
by Anonymous User
Not applicable
ArcGIS for Server Publishing Patch
Have you pushed through the AGS Server Publishing patch?
ArchitSrivastava1
New Contributor III
Hello John,
Mostly we encounter these issues due to missing permissions of ArcGIS Server Account on the following location:
  • Drive:\arcgisserver.
  • Drive:\Python27.
  • Drive:\Program Files\ArcGIS\Server.
  • Run the Configure ArcGIS Server account.
Applying explicit permissions for ArcGIS Server account should take care of this error.
Hope it helps!
Regards,
Archit
