Services missing after Enterprise upgrade
1136
5
03-29-2019 06:14 AM
ReidWebb
Hello! I just finished upgrading my Enterprise (Portal and Server) to 10.6.1 from 10.5.1. Everything seemed to install smoothly but my services are now missing. I can't see them in ArcCatalog or Server Manager.
I cleared my browser cache and rebooted the hosting server (single-machine) but didn't help.
Like an idiot, I didn't back up my site before the upgrade. I backed up Portal but not Server
Please help! Thank you!
PanagiotisPapadopoulos
Do you have a valid license file for 10.6.1 version?
ReidWebb
i found this post where it says to check the version.json file. That file told me it had not been updated so I followed the rest of the directions to restart the Continue Upgrade process. That process completed but my services are still missing.
Sorry  i just saw you have a second question for the same Issue
https://community.esri.com/thread/227805-missing-all-services-after-upgrade
ReidWebb
well, it's related but not the same. still haven't figured out the problem. it appears licensing is valid but still trying to be sure.
ReidWebb
I figured it out. When you run the ArcGIS authorization utility, it shows you the Authorization Number (ECPXXXXXXXXX) number that it reads from the provisioning file.
The problem was that, by default, the utility was reading the wrong Authorization Number from the provisioning file. It was reading the Image Server Authorization Number to authorize Server instead of the Server Standard Authorization Number. Once my GIS POC sent me the screenshot showing the two different numbers, I realized what was happening and changed the ECP number to match Server instead of Image Server.
