I keep getting this message: "error": {
"code": 400,
"message": "Unable to complete operation.",
"details": [
"The current version does not support editing (base, consistent, or closed) [An open transaction was detected. All user transactions must be closed prior to StartEditing.]"
when i try to create feature via the REST endpoint on a Feature Service using the addFeatures method.It appears to be related to some kind of ArcSDE locking.This is a 10.1 arc server install using OracleI can get the edits to work once in a while, and some times for an hour or two on end. but then it breaks again.i confirm in catalog that there are no locks on the sde connection used in the mxd for the feature service.I thought edits through the REST api would handle the opening and closing of the edit session.I never explicitly call "StartEditing" i just craft a string request in C# to send to the rest endpoint.What is going on here?
