Hi Jeff,
Thank you for your answer!
Yes, the server restarted after the configuration was changed. I did this more than once, but the result was the same. Also yes, the system upgraded from the 10.8 to 10.9.1, and I configured manually to the TLSv1.2. Before I set the configuration to the TLSv1.2, it had also the configuration TLSv1.1.
What is weird is that I have done this to many severs with the same conditions, but only one didn't stop accepting TLSv1.1.
Yes, I am using the OpenSSL to validate the TLS protocol enabled. Here part of my script to check the protocol.
(OpenSSL.SSL.TLSv1_METHOD, "TLSv1.0"),
(OpenSSL.SSL.TLSv1_1_METHOD, "TLSv1.1"),
(OpenSSL.SSL.TLSv1_2_METHOD, "TLSv1.2"),
Many thanks!
Felipe
