Hey All,
We have a federated server which, when it was initially federated, a single Web Adaptor URL was used as the admin URL for the server, e.g. https://wa1.domain.com/arcgis. We now have a Load Balancer in front of two Web Adaptors which balance between the ArcGIS Server machines within this site. Therefore, we would like to update the federated Admin URL to point to https://lb.domain.com/arcgis. We are no longer in the position to un-federate/re-federate due to usage of the production system.
Are we able to use the Portal sharing/rest directory to perform an 'update server' and change the Admin URL?
If so, are there any envisaged knock-on effects we should be aware of, or check for?
Note: we only want to change the Admin URL, not the ArcGIS Server URL.
Thanks in advance,
Jordan
