Update Time Slider Extent Without Disabling/Enabling Time in Map
757
06-07-2017 01:24 PM
CarmellaBurdi1
New Contributor III
Hello all,
I have some questions about time sliders extents and auto-populating them.
I am using Portal 10.4 and cannot upgrade at this time.
  • I have a web application that has a basemap with a time aware layer in it.
  • I have a GP service that performs some calculations - one of which is updating my time fields that inform the time aware layer and my time slider.
  • I have a time slider widget in my app that I want to then use to show the updated time data that my GP service just calculated.
  • However, the time aware data layer that's in my map/app does not update when the GP service is run... making it pretty useless as you'd have to then open up the map you created, turn off disable time, re-enable time, etc....
I'm looking for a way to make sure that the map updates itself when you run the GP service.
I found this thread here that kind of sort of answers my questions - but I'm not really using the Java Script
API and my JS is limited. I could use it if someone could give me very step-by-step instructions. I'm not totally without the ability to alter the JS. I'm using web app builder for developers 2.4.
Any help would be appreciated!
Thanks!
Carmie
