Use Managed Service Account in webgisdr
292
12-09-2021 03:08 PM
LucasMurray2
Occasional Contributor II
Is there a way to set up a managed service account to use as the portal admin account within webgisdr?  I'm currently using my account to run the backup process and everytime my password changes, I have to update webgisdr with the new credentials.
TonyContreras_Frisco_TX
Occasional Contributor III
The properties file stores the Portal admin account credentials. Are you able to use a built-in admin account and put its credentials in the properties file?
The webgsdr tool can be run with a managed service account as long as it is an administrator on the Portal server running the tool(Check Run with highest privileges in Windows Task Scheduler).
