Web Adaptor and SQL server in cloud architecture
562
09-15-2020 06:23 AM
MelanieFournier1
i am interested in installing my development environment on the cloud. I saw that I could use the enterprise builder for cloud and I will get all the components on one machine.
I was wondering if someone can recommand the best practices regarding the web adaptors? Do I need to get one for portal and one for server? Or if I have a reverse proxy they are not mandatory?
And if I want to get a database, can I install SQL server express on the same machine, or is that supposed to go on another server? I only deplyed architecture on premises, and cloud is totally new for me.
Thanks.
Mélanie
JoriS
by Esri Contributor
Hi Mélanie,
To answer your question regarding web adaptors please take a look here: https://enterprise.arcgis.com/en/web-adaptor/10.8/install/iis/getting-started-with-the-arcgis-web-ad...
While it is best practice to have one web adaptor for Server and one for Portal, you can certainly utilize one for both.
In addition, here is a brief note on web adaptors and reverse proxies:
If you do not use ArcGIS Web Adaptor in your deployment, ensure that the reverse proxy server's context name only goes one URL level deep. For example, you can have a reverse proxy URL such as https://proxy.domain.com/enterprise, but you cannot have a reverse proxy URL such as https://proxy.domain.com/myorg/enterprise.
Please take a look here for more documentation on reverse proxieshttps://enterprise.arcgis.com/en/web-adaptor/latest/install/iis/using-a-reverse-proxy-server-with-po...
Last, these two links will introduce you to Enterprise in the cloud and Enterprise Databases in the cloud
https://enterprise.arcgis.com/en/cloud/latest/intro/enterprise-in-cloud.htm
https://enterprise.arcgis.com/en/server/latest/cloud/amazon/enterprise-geodatabases-in-sql-server-in...
I hope this helps!
Enterprise Support Analyst
