When upgrading License Manager from 10.5 to 2023, does it keep the old licenses or do you have to reimport them?
484
01-22-2024 11:12 AM
BrettBlankner
New Contributor II
We are about to upgrade a license manager from 10.5.1 to 2023, but are wondering if it will lose all our loaded concurrent ArcMap (10.5 - 10.8) licenses and we will need to reload our licenses into it?  Or does it keep the old licenses onboard with the upgrade and they will start working immediately when we start running the new license server?
CodyPatterson
Occasional Contributor III
Hey @BrettBlankner
From my experience going from 2021 (or 2022 I can't remember currently), I did have to reinsert the license authorization file from portal to get the licenses reloaded onto there.
Hope that helps!
Cody
Scott_Tansley
MVP Regular Contributor
The documentations suggests not:
https://desktop.arcgis.com/en/license-manager/latest/license-manager-installation-and-startup.htm#ES...
You should only need to stop the license service.
Scott Tansley
https://www.linkedin.com/in/scotttansley/
GIS_geek
New Contributor III
@BrettBlankner my organization moved from 10.5.1 to 2022 and did not lose the loaded licenses.
hlindemann
New Contributor III
Hi @BrettBlankner, normally this is not a problem, just keep in mind that you will have to also open port 27000 if you have a firewall running in addition to your licensing port, otherwise when you upgrade pro your latest pro will not work.
Kind Regards
Henry
