ArcGIS Experience Builder Blog
Latest Activity
(79 Posts)
Jianxia
A sneak peek into new features in Experience Builder in ArcGIS Enterprise 11.3.
Read more...
more
7 5 960
StephanieUmeh
Here are some helpful resources that will help you create interactive and immersive web apps using ArcGIS Experience Builder.
Read more...
more
6 1 878
ShareUser
Esri Community Manager
When creating and updating features using Forms in the Editor widget, calculated expressions can be triggered to populate field values automatically.
The challenge: values for fields with calculated expressions cannot be edited or recalculated on demand, while editable fields do not support calculated expressions.
A workaround is proposed in this article.
Read more...
more
0 10 298
Jianxia
Version 1.14 of Experience Builder Developer Edition is Now Available. It adds the Select widget, ability to filter multiple layers, and URL parameters for Map and Search widgets. It also provides guidance on sharing code between widgets and automating your app deployments.
Read more...
more
3 2 1,134
Jianxia
The Select widget, group filter, and map URL parameters are available. Other improvements include the ability to search for and re-order layers in the Map Layers widget, getting statistics on numeric fields, and support for raster analysis in the Analysis widget.
Read more...
more
5 5 585
FasilTiru
The Business Analyst widget features several new features in this update.
Read more...
more
3 2 1,040
AzizaParveen1
We have added some great enhancements in Near Me in February 2024 ArcGIS Online update. The updates include adding more functional parities with Near Me, Situation Awareness, Info summary and Screening in Web AppBuilder widget. Major enhancements we have added are list virtualization to improve performance,  a configuration parameter to show map symbols in widget panel, use all features from a layer as input search area and many more small but valuable features. We also organize the configuration experience for greater usability and better user experience.
Summary of the key enhancements in February update
  • The widget uses list virtualization to improve run time performance. Also, if you have lot of features in your web map, you may consider turning on the client side query option in the Map widget for your map to have better performance.
  • In results, you can include map symbols representing the symbology of features that meet the analysis criteria.
  • You have option now not to show input location address in the widget panel.
  • You can use data added at run time with the Add Data widget as input data for analysis. As for example, if you have a shapefile or file geodatabase layer for you survey areas, you can upload the layer using Add Data widget and then use Set location data action to use that layer as input search area in Near me for finding features within your survey polygons.
  • You can choose which sketch tools for drawing an input location appear in the widget panel at run time.
  • You can create an input search area using all features from a layer through Map Layers widget.
  • When any analysis only returns one feature, the widget now zooms to that feature automatically.
  • When exporting to CSV format, the name of the input layer becomes the name of the .csv file.
Related resources
The following docs will be updated tomorrow (29th February, 2024) after ArcGIS Online update
more
11 1 603
Jianxia
Upcoming new features in ArcGIS Experience Builder in ArcGIS Online February 2024 release late this week.
Read more...
more
12 9 1,448
GlenShepherd
Question:
  • If ArcGIS Online provisions users with "utility services" to perform certain tasks; and
  • Utility Services consume credits in some instances; and
  • Some ArcGIS Experience Builder widgets can connect to utility services in order to function; then
  • WHICH ONES WILL CONSUME OUR CREDITS?
Answer:
The following widgets can consume credits when used through ArcGIS Experience Builder (ArcGIS Online only)
Directions:
  • The 'routing' utility service consumes credits
  • Must be a signed-in ArcGIS Online user to use the tool
Business Analyst:
  • Configuring this widget with the 'geoenrichment' service consumes credits
Analysis:
  • This widget's built-in spatial analysis tools consume credits. Every tool has an Estimate credits button, which you can use to see how many credits an analysis will consume before you run it, located above the Run and Back buttons. The button indicates if an analysis does not consume credits.
Add Data (subscriber content):
  • ArcGIS Living Atlas of the World includes three levels of content: publicly available content, subscriber content, and premium content. Subscriber content, such as Landsat 8 imagery, requires an organizational subscription account to access. Premium content is subscriber content that consumes credits, such as demographic and lifestyle layers.
  • The widget prompts the user to sign in if they try to add subscriber content
Documentation for understanding credit use in ArcGIS Online: https://doc.arcgis.com/en/arcgis-online/administer/credits.htm
more
6 0 696
Jianxia
Features planned for 2024
Read more...
more
43 67 14.7K
316 Subscribers
