Experience Builder has so much potential, but we can't implement it until a batch editor capability is added. It is so convenient to be able to select multiple features and edit their attributes simultaneously rather than selecting one-by-one.
Agreed. We need this functionality, and are currently having to combine some elements from Exp. Builder and some from Web AppBuilder to achieve our desired workflow.
The Batch Editor Widget is high on our requirement's list for ArcGIS Experience Builder.
Our workflows require users to be able to select features on a map OR a table, and update the attributes values of ALL of those selected features at once. Users may be updating up to 50 features and cannot do this one at a time.
The Batch Attribute Editor in ArcGIS Web AppBuilder is an ideal workflow which needs to be incorporated into the Edit Widget in Experience Builder. I would go even further and suggest that the Editor Widget in Web Experience Builder adopt a similar user experience that can be found in ArcGIS Pro where the user interface allows the users to visualise the feature selection in a list below the layer selection (see image attached)
The features being edited also need to be driven from features selected from a table too, not just the map.
Batch editor (also filter) is also a highly desired tool for experience builder. I'd love to move away from WebApp onto experience builder but can't without tools such as this.
Our organization also needs this. The Java script updates are forcing us to Experience Builder only to find that batch editing is not an option. Why transition WAB users to Experience Builder if this isn't an option??
Yes this is needed functionality for users editing in the AGO environment
Our org also NEEDS batch editing. Just not practical to ask users to edit one-by-one after having batch editing with the existing WebApp builds.
So frustrating how ESRI develops their new products and pushes their usage but they always seem to come with limitations. The new and improved products should at minimum MATCH the functionality and capabilities of the products they are replacing.
Unfortunately looks like its not on the roadmap for 2023 https://community.esri.com/t5/arcgis-experience-builder-blog/arcgis-experience-builder-2023-roadmap/...
Yes, agreed! Our company would like this widget to be implemented in experience builder too. We are looking at migrating from Web App Builder to Experience Builder, and this functionality is required for us to move forward.
Agreed, Experience Builder is a non-starter for my organization without batch attribute editing.
I've just been presented with a need for this feature. Is this on the Dev team's roadmap?
