Would be great if a Button-Widget added to the Widget Controller would have the option to execute the "button click" directly if pressed on the Widget Controller instead of opening a card with the button... just to click that again.
Yes!! This needs to happen.
Opening a card that we cannot edit (at least I haven't figured out how to edit this yet) isn't that helpful! I have a giant button with some text - very crude - that links to a fixed window.
A workaround: configure a button that look the same as the controller button, and put it directly below the controller (not in the controller).
