ArcGIS Experience Builder Blog
320
3.7M
79
Open | You should be able to change the icon for the "Clear results" after performing a query widget. I believe it may be co... by CameronLacelle Occasional Contributor 5 0 | 5 | 0 | |
Open | It would be very helpful and handy if ExB and other apps could visualize overlapping point features in a spiderfy-sty... by Christian_Sebaly New Contributor III 1 0 | 1 | 0 | |
Open | URL Parameters, such as seen here: https://doc.arcgis.com/en/experience-builder/latest/build-apps/url-parameters.htmA... by Gordon_Aberdeen New Contributor III 1 0 | 1 | 0 | |
Open | Like in the Layer List widget in WebappBuilder it would be nice to show tables which are enclosed in the hosted featu... by MarkVonk New Contributor II 2 0 | 2 | 0 | |
Open | Sometimes I am building experience builder apps that are going to be displayed at a certain screen size. I would be n... by Greg_Mattis Occasional Contributor II 13 3 | 13 | 3 | |
Open | I don't know much of a better way to explain the issue other than that entering text and dynamic attributes in Experi... by ZachBodenner MVP Regular Contributor 12 4 | 12 | 4 | |
Open | Widget which would enable exporting shapefiles from selected features in the map or from the selection in the table o... by MagdaDro New Contributor II 5 1 | 5 | 1 | |
Open | Web maps aren’t my area of expertise. And my organization uses Web App Builder at the moment, not Experience Builder.... by Bud Notable Contributor 2 2 | 2 | 2 | |
Open | Request to change the behavior and current limitations of the Extract Data tool, which is in the Analysis widget in E... by Juan_Toro-Killion New Contributor III 3 0 | 3 | 0 | |
Open | I have an idea about using selected features in an analysis tool in Experience BuilderIf I use the select tool to sel... by LarsElmkær_Chwastek Occasional Contributor 4 1 | 4 | 1 | |
Open | In Experience Builder, rearranging items on the page requires dragging and dropping within the GUI. For example, if I... by ZachBodenner MVP Regular Contributor 3 0 | 3 | 0 | |
Open | Hi Esri, The near-me widget functionality is one that we can make good use of for a particular product in Experience ... by Sibe New Contributor II 2 1 | 2 | 1 | |
Open | If there's no option to import Web AppBuilder apps into Experience Builder and no support for Web AppBuilder post its... by AbiDhakal Occasional Contributor III 3 0 | 3 | 0 | |
Open | In the very near future, Web AppBuilder is slated to be replaced by Experience Builder. To ensure a smooth transition... by AbiDhakal Occasional Contributor III 18 7 | 18 | 7 | |
Open | I would like this for a few reasons:- real estate of the map- users are most likely going to be making a brand new se... by Laura MVP Regular Contributor 1 2 | 1 | 2 |
Idea Submission Guidelines
User | Count |
22 | |
13 | |
12 | |
12 | |
10 |
