List Widget Selection Shows Pop-up
468
08-16-2023 02:47 PM
Status: Open
BrettFrahm
Occasional Contributor II
The List Widget does not bring up the pop-up of the selected feature. There should be a setting that allows for you enable/disable this feature.
Feature selected from List Widget but not pop-up appears. Pop-up will appear if I select the point feature manually.
3 Comments
DaveFullerton
BrettFrahm
@DaveFullerton thank you for pointing this out. I did not come across this is in my searches. Yes your idea is the same as mine. I'll recommend to ESRI that this idea should be closed since yours was created first.
BrettFrahm
@SarahRijneke , @Laura , @KellieHeney@Pierredp@williamsonsa_fultonhogan
Thank you for liking my idea. I encourage all of you to also Kudo this post too (https://community.esri.com/t5/arcgis-experience-builder-ideas/an-action-on-the-list-widget-to-open-t...) which is the same idea as mine but was created first.
