Hi @AlixVezina ,
I have a question about the Add Data widget in AGOL.
Is it expected behavior that when you use the Add Data widget to add a hosted feature service to a map in EB that, if that service is editable, it will then appear in the map and the Edit widget, when you, the EB author, have not configured the app for that newly added service to be editable?
Seems that setting all the configurations for the services that are available in the map and in the edit widget go out the window if you then can add any editable service to the map with the add data widget.
Thank you for any insight!
