It seems that the ability to customize Experience Builder bookmarks with uploaded images has vanished. Not sure if this is directly related to the recent AGOL update, but I noticed it for the first time yesterday. My existing bookmark images, which I added some weeks back, are still there, but I have no way to modify them or to create a new bookmark that contains an image. I can only manually set a map extent which then acts as the boomark's thumbnail. Are others finding this? Was this an intentional change? Would love to know if there is something I am missing!
Thanks in advance for any help/insight!
Hi @CameronAndrew ,
Thanks for your feedback. But unfortunately, we cannot reproduce the problem you are seeing. Did you see the "Custom" option for the bookmark image source when you click on a bookmark item?
If you are still seeing this problem, could you share your application to us for further investigation?
Wei
Hello, @WeiYing1 .
I do not see the "Custom" option any longer. When I click a bookmark, it simply enables the text box to edit the name of the bookmark, or I can click the map icon (as I have in the screenshot below), which allows me to set the map extent.
@CameronAndrew can you click in the middle of an bookmark item from the list? You should be able to expand the image setting of a bookmark
Thanks so much @WeiYing1 . That 'works', but it is extremely glitchy and inconsistent in its functionality. Sometimes I can get to it with a single click, other times I have to click what seems like 15 times before it finally stays open.
Thanks a lot for your feedback. We will try to improve the UX.
