Hey,
I have done some digging but no conclusive results. I am trying to display related records when a feature is being selected, either filter or highlight or select is fine. I have tried using Map Widget Action Triggers and List Widget Action triggers as I have read from other posts.
The relationship is Many to Many which has an intermediary table that was created in ArcGIS Pro and published to ArcGIS Online. Now in the Web Map Viewer, related records work and I can see related records when clicking on either feature from layer 1 or feature from layer 2, as they are in M:N relationship. But this functionality is limited, I cannot highlight or display these related records only navigate to them via the popup.
I wanted to be able to either set an Action Trigger in the Map Widget when feature 1 is selected all the related records are highlighted/selected or filtered. None of this works. The Origin and Foreign Keys of the intermediary table are not available to select and only the origin keys of both feature classes are available and they do not work:
Map Widget Action Trigger configured as below and also I tried with the List Widget, same no result. If I remove the toggle for the trigger/action connection then obviously everything is selected once the feature 1 is selected. So seems like Many to Many is not supported? I tried adding the intermediary relationship table to the web map but just got an error.
Many thanks if anyone can confirm if this functionality is in ExB?
Regards,
Serj
