Hello! Is there any widgets that would allow users to download data by selection on the map in ESRI Experience Builder?
Basically, I'd like the viewer to be able to select data on the map by polygon, rectangle, etc. or by filtering, and then downloading them.
Would be great if that is possible, or should I stick to Web App Builder?
Hey Albert Kochaphum, as Shay Lavi has mentioned could be coded with dev edition.
Hi Albert,
At this point, I don't believe such a widget exists, but it can be coded if you use the developer edition.
I am just finding your question after searching for the same need. Did you find or develop a solution to select data and download the table for them? Thanks.
