Edit widget versus Survey widget
106
2 weeks ago
clt_cabq
I'm curious if anyone has experience using either or both the edit widget or the survey widget and what that experience has been like, and if you would recommend one approach versus the other. My application is going to have a feature layer with up to 3 related tables that will be updated by end users. The survey widget seems attractive in part because we can develop reports on the s123 side that users may want for various purposes. The edit widget with its ability to edit related records seems pretty straightforward and simple to use.
Any thoughts if there are best practices or scenarios where one of these tools works better than the other?
