I am having the following error come up when I open my experience builder project in AGOL. This project was functioning well and there have been no changes for over a month. Then it is suddenly returning the following error: this.getLayerDataSource(...).getCurrentQueryParams is not a function.
When I view the experience builder project it looks fine initially but as soon as I click anywhere on it errors shows up. Specifically the list view of the attachments will then display with an error and when I click on the table widget an error displays. If I go into edit mode and try to make any changes the error takes up the project and I can not do anything.
Any ideas? Thanks,
Most likely there is an issue with the featureLayer you are trying to query. Make sure it is available and functioning properly.
Hi did you have any luck resolving this? I am having similar issues.
